Simon Blythe
The good bits: good roof, new front disks and pads - relatively new rears, new tyres all round , nice interior and dry all round.
Too early to say if it will be broken but hopefully it will make a nice car
Cheers palGood luck mate
I think you may be right mate - want to cure the misfire first though - a set of used injectors on eBay is £35 Very tempting upgrade at some point thoughThe gunk in the fuel cap may just be from the car doing a lot of short journeys, quite common on BMW's. Wipe it off as much as possible and give it a good long blast and get it up to temperature for a while plus an oil change will do it no harm. As for the gasket on the inlet manifold, it's the perfect excuse to do the M50 upgrade![]()
I was thinking the same but it's quite costly though circa £300/490. I know it's been discussed in depth but do you really think it's worth doing? I've always thought the 2.8 doesn't breath or rev particularly well.Looks ready for an M50 conversion!
You can see how restricted the M52 mani is in your first picture the M50 opens that right out to the gaskit to match the head.
Glad you getting to grips with the niggles and its all worth while![]()
