Can't see properly but looks like part of the actual body skeleton. You could wade through diagrams here to see if it's a detachable part https://www.realoem.com/bmw/enUS/showparts?id=CH72-EUR---Z3-BMW-Z3 1.9&diagId=41_0033i ment the rotten panel near the strut what the earth strap connected to cheers
By rotten do you mean the small patches of surface rust? Or is there something else going on I'm not seeing?i ment the rotten panel near the strut what the earth strap connected to cheers
The drawing is misleading, as it shows some OSF parts and some NSF parts. It is the text that you need to read in order to find out what is available and their associated part numbers.So in the diagram all of the OSF parts appear as Z3, all of the NSF parts appear e36.
Yes I believe item 3 is the part I need but if it looks like it does in the diagram then it’s no good, it’s £144.95 plus VAT, it is called ‘section of left front wheel housing’ item 5 may be required also.
