hi all can anyone please tell me the best place to put the car on axle stands,i am doing bits on the rear and then on the front,hope some one has done the same and could please advise me ,many thanks.pete S:smile
sorry i mean the position of the axle stands on the car.pete59 said:hi all can anyone please tell me the best place to put the car on axle stands,i am doing bits on the rear and then on the front,hope some one has done the same and could please advise me ,many thanks.pete S:smile
As Punch once said: "That's the way to do it" :-@GazHyde said:Perhaps you could take a few pictures as you work and post them up here.![]()
Deano can you clarify this please - I always understood that you should NOT jack up the rear using the diff :-sdeano1712 said:At the rear the best way is to put a trolley jack under the middle of the differential.
I think it is easily strong enough. The diff mounts to the subframe which is mounted to the car via 2x M14 studs at the front, where most of the loads go. I suggest there will be more loads going through the subframe whilst driving, than when lifting. Before I strengthened the boot floor on my car I supported the whole weight of the rear of the car at the (single) point of the rear diff mounting. I measured the deflection of boot floor with a straight edge and could detect nothing.Titan said:Deano can you clarify this please - I always understood that you should NOT jack up the rear using the diff :-s
There was some discussion about this last year and although it may be common practice, it was not recommended.
It could be related to the potential boot floor weld problems on Zeds but it's just as easy to use the cross members or wishbones.
