Eml light on bmw z3 got code read by mechanic came up as thermostat fault changed that went for drive came on again but found crack case breather pipe disconnected reconnected it will eml light reset itself or will it need to be reset by obd tool
Knew you would be able to answer the questionIf it's like mine when the cam sensor failed it will need to be cleared.
ps. I'm sorry, I saw this earlier and clean forgot to come back and reply.![]()
If you are after stainless then google Longlife exhausts and you should be able to find a supplier/franchisee in your area. You can then discuss requirements with them and that can tailor it to suit your `sound' needs. Another one is Cobra who are based in SheffieldHi does anybody know of an exhaust system supplier poss stainless steel for my z3 she's a 1.9 8v and I'm in the Bolton area near gtr Manchester thanks jay
Just ordered this on your suggestion. Bought a different unit to use with my computer but the lap top is too old so will give this a try! JIMEBay C110 and make sure you get the cable adaptor in the kit. This is the one I have and it clears most codes. Takes a little getting used too but great once you have mastered it.
http://pages.ebay.com/link/?nav=item.view&alt=web&id=231569832018&globalID=EBAY-GB
Hope that helps
I hope so, I just bought one too!! JIM@Jlp glad it's worked out ok. It's an easy unit to use too.
