Has anyone got an easy fix to liven up ciggy socket at position 1 on key. Mines position 2, I use a Blutooth to FM transmitter for music so would like to have it work without the need for ignition on position 2... ?
I thought it was permanently live?
I think mine is permanently live to
Thankyou gentlemen, well mine aint, however if yours all are it surely must be an easy one to remedy.. Much appreciated..ciggy lighter next to handbrake is always live
OK, I do have power to it but only position 2 or running, A PITA if I want to listen to tethered tunes whilst parked up.. Based on the comments here though, I am wondering if it hasnt already been modded to only be live with ignition, or the blutooth would run 24/7.. But they cocked it up a bit by taking power from position 2 circuit, when it should be on 1... I will investigate....Check your fuse listings on the manual - it could simply be a fuse that needs fixing.
To be fair I couldn't find it in the fuse listing - but someone on here may know. Best of luck
This may help
No power to cigarette lighter
I dont need this to light up but I do need it to power my sat nav so any thoughts> I took the panel below the glove box out but for the life of me I couldnt see the fuses and I cant see the lighter fuse on the little chart thats located on the panel so any advice would be appreciatedzroadster.org
That would me my guess yes,They were probably worried about stuff draining the battery overnight or something!![]()
