Whilst checking under the car the other week I noticed oil contamination around the inboard drive shaft coupling to the diff. There is more contamination than shown in the photo below as the shaft is rotated and some oil has flicked onto the underbody.
Having spent a fair amount of time searching forums etc, I have found very little information about this type of leak and would appreciate your comments on my thoughts and if I am right or not, and how to repair.
To help with the location of the problem I have included a couple of screen shots from RealOEM also
Oil leak
![20170614_164431.jpg 20170614_164431.jpg](https://zroadster.org/data/attachments/60/60091-73def414bbd280062a53df2ed4ed28c8.jpg)
Output shaft picture
![Outout shaft picture.PNG Outout shaft picture.PNG](https://zroadster.org/data/attachments/60/60092-0a9494307e10446ec64e01b6b92fd384.jpg)
Output shat text
![output shaft text.PNG output shaft text.PNG](https://zroadster.org/data/attachments/60/60093-3b89eb67c0f54e574a8b279bda0f168b.jpg)
Drive flange picture
![Drive flange.PNG Drive flange.PNG](https://zroadster.org/data/attachments/60/60094-843608527abc191fafd050d657be56c8.jpg)
Drive flange text
![Drive flange text.PNG Drive flange text.PNG](https://zroadster.org/data/attachments/60/60095-d7fc1658fd32f5720ea9bae662758d96.jpg)
The oil is coming from the output shaft gasket (left element of 6 in Pic 1) and the drive flange (1 in Pic 2).
I think that the shaft seal with lock ring (6 in Pic 2) has failed.
From what I have read, to release the output shaft the 6 torx screws (3 in Pic 1) are removed and the shaft is then free to separate from the drive flange which can then be pulled from the diff housing using a 3-leg puller and some spacers.
To remove the shaft seal there is a lock ring (10 in Pic 2) which is a circlip that sits inside the inner groove shown on the shaft seal. Can anybody confirm this or explain the actual arrangement/method please? Are there any parts other than the oil seal and lock ring that must be replaced at the same time?
Thanks in advance for any guidance you can give.
Oil leak
Output shat text
Drive flange text
