This is a great solution for the z4 roof drain problem, 14mm OD Pvc tubing is a perfect fit for the grommet, I'll be adding some silicone to the plug before putting it in the hole. Then with the florescent pipe it's easier to spot a blockage. Run the pipe to the the splash guard drilling a 15mm hole with a hollow grommet and fit the cross section of the original drain valve at the bottom. This was help with debris getting back into the pipe.
![Thinking face :thinking: 🤔](https://cdn.jsdelivr.net/gh/joypixels/emoji-assets@5.0/png/64/1f914.png)
![OK hand :ok_hand: 👌](https://cdn.jsdelivr.net/gh/joypixels/emoji-assets@5.0/png/64/1f44c.png)
