Just got this through the post, I'll give it a whirl later in the week. As much as I like polishing manually this will take the pain and time out of tight areas, especially with the flexible attachment and pads.
I'll see if I can get betterCan get a decent polish now you have a machine![]()
That would be badDon’t get confused and pick up an angle grinder.......![]()
Direct drive mate.First thing, get used to putting the cable over your shoulder, is it direct drive or da
Excellent, a proper polisher but be aware yoiu can do some serious damage, your biggest risk is panel edges and body lines, on panel edges make sure the spin is away from the edge, meaning that the mop is spinning off the panel toeards the edge if that makes senseDirect drive mate.
Cheers mate, notedExcellent, a proper polisher but be aware yoiu can do some serious damage, your biggest risk is panel edges and body lines, on panel edges make sure the spin is away from the edge, meaning that the mop is spinning off the panel toeards the edge if that makes sense
Is there a guarantee?Just got this through the post, I'll give it a whirl later in the week. As much as I like polishing manually this will take the pain and time out of tight areas, especially with the flexible attachment and pads.
ProbablyIs there a guarantee?
I would get a replacement. that one looks all blurry,
Hang on ....Is this a mini one with the 1", 2" and 3" pads? I've been looking at a similar one on Amazon but it hasn't got that flexi attachment. Have you got a link to this one please?
https://www.amazon.co.uk/s?k=spta+rotary+flexi+tool&ref=nb_sb_nossIs this a mini one with the 1", 2" and 3" pads? I've been looking at a similar one on Amazon but it hasn't got that flexi attachment. Have you got a link to this one please?
Thanks, that link has just come up with a load of different products. But as you mention SPTA it's the same one I was looking athttps://www.amazon.co.uk/s?k=spta+rotary+flexi+tool&ref=nb_sb_noss
I got this one, there are others with no pads so cheaper.
3rd and 8th products down are the flexi lines. One for £47 with a gazillion pads and one for £8 just the flexi lineThanks, that link has just come up with a load of different products. But as you mention SPTA it's the same one I was looking at![]()
