Thought a few pics of the finished 250SWB might grace the beauty parlour:
Got 1/2 a V12 already, will need to save up for the other 1/2!Beatiful job, just needs a V12 under the bonnet.![]()
Four choices with these:Another fine build, it's the attention to detail that makes the difference with these kits. There's a coupe version for sale on fb marketplace, but under the skin and the interior it's just a rough job. No comparison to your excellent standard of work, superb.![]()
Forgot to mention that bit, cheers SteveBase kit price is for the Tribute kit, almost double for the California kit
I know what you mean about the yellow plates, and I do intend to change the reg to A/B plates on both cars at some point next year. What I am unlikely to do is, change to black plates (the fuzz around here have bugger all to do but pull motorists) much as i would like to.You have got to get rid of that horrible yellow number plate.
CHERISHED NUMBER PLATE -PTU 973B - PT PTU CREWE ROLLS ROYCE BENTLEY 1964 PTU | eBay
We provide a full service, from your initial enquiry to the completed cherished number plate transfer to your vehicle. We are also a recognised DVLA Number Plate Supplier 13844. To complete the transfer to your vehicle we will require the following.www.ebay.co.uk
£200 including the transfer fee which you can now do online. Although you will join the naughty boys club, I have had black and silver plates fitted to mine since I built and have never had a tug. So long as they are clear and not miss spaced they arn't bothered. Keep a pair of yellow plates in the boot for MOT's. The amount of "car buffs" who have been heard saying "it's original because it was registered in 1964" has surprised me. Everyone knows that you can't put a newer plate on an older car but not many people are aware that you can put an older plate on a newer car. Worth fitting just to throw the "anoraks" off.
Reversing light/fog light
Nothing screams "kit car" more than bolt on fog and reversing lights.
Alfa Romeo 105 SeriesAlfa Romeo 105 Series GT/GTV Reversing Light Unit | eBay
Reversing light complete unit with lens and rubber backing to fit all 1300-1750 GT/GTVs. PICK UP OPTION. © VeloceSport. See more. You might also like.www.ebay.co.uk
The Alfa reversing light was also fitted to Daytona's and Dino's as well as a few others. The fitting is sloped so should fit the 250 as well.
I glued a LED brake/tail light to the rear of the Lucas reflector, sand down the front of the LED bulb and glue to the rear of the reflector after tou have removed the foil. Wire up the brake and tail light together to make it extra bright.
For my reversing light I fitted 25w/25w 12v motorcycle bulb to my indicators, this gives me a 25w indicators and when it is put into reverse both indicators light up with 25w in both sides, plenty bright enough for reversing lights, you just have to live with amber reversing lights.
On the California, I would fit the Alfa reversing light and fit a brake/tail LED bulb to the reflector in the lower section of the MGB lens.
Thanks a lot.Looks amazing - well done
Thanks very muchUtterly gorgeous![]()
