How do you pump...
Jamezee
Peak District
Your tyres up?
Foot pump?
Plug in to fag lighter pump?
Garage forecourt?
Mouth????
I ask because I am fed up of going to the garage with my 20p coin and am thinking of getting a 'plug in', a major investment I know ;)
B
badman gee
Guest
garage, its easier. its not just the 20p however, its the fuel cost there and back!
at least 12 mile of me!
s:mrgreen
Titan
Moderator
North North Yorkshire
sDrive35i
I bought a Bonaire Direct Drive 12v pump with flexi-coil air line from Costco.
£30 - but with 4 cars and several push bikes in the family it has been a worthy investment ;)
Titan
Moderator
sDrive35i
Do I sense a business opportunity here?
Free air to Zedders - but you might have to buy me a new battery :))
GazHyde
Administrator
Administrator
Z4 MR
I've had a cheap Halfords cigarette lighter type compressor for about 10years. Works perfectly fine, and seems pretty accurate. Can take a while if a tyre is really low on pressure, but for you can't beat it for convenience.
Boysie
West Chiltington, West Sussex
M Roadster S50
Hi Titan
That's a great buy, ideal Xmas pressie
I thought most cars these days had small compressors, to get you out of trouble
I bought a small compressor from Machine Mart for the garage,
great for inflating tyres and blowing rubbish out of the garage.
Thought I'd try a bit of spraying one day "Not the ///M"
NeRo
Moderator
Staff member
Linlithgow
I have a Michelin cigarette lighter type compressor with digital display,
However, I always check the pressures afterwards with a tyre pressure gauge.
Garythefish
Romford Essex
S54 Z3M
I have a small compressor in the garage now, I did use a plug-in before that, worked fine.
WeeJimmy
I use a compressor to fill an old calor gas bottle. It gives enough portable compressed air to pump up the tyres or to undo the wheel nuts.
Boysie
M Roadster S50
Thats sounds a bit dangerous to me 8-|
MAURICE THE MARTIAN
Tameside-via Mars...or..SK16.
Z4 3.0SE AUTO
And where do you store it whilst out Zedding,in the boot :-?
Think your username should be dangerous Jimmy s;)
:ymalien:
WeeJimmy
Calor gas bottles are rated to 8 bar (same as the compressor), so it's no more dangerous than standing next to the compressor tank.
A bit hairy when I took the top off the tank. An empty tank is NEVER empty, and butane is denser than air. I used a remotely controlled tie-down strap and adjustable spanner. Like opening a bomb for the first time, seeing the insides and watching for sparks X_X. Appropriate safety precautions were observed :-? .
MAURICE THE MARTIAN
Z4 3.0SE AUTO
Thanks for the explanation,Dangerous Jimmy, s:D
Methinks however i`ll continue to use my Halfrauds plug in lighter compressor.
Dread to think how you generate the power for your christmas lights s:D s:D
Have a safe Xmas :ymparty:
:ymalien:
r37
air + water are free at my local tescos, odd. But i use a foot pump bought from an argos bargain bin for 50p, 2 years of heavy workboots has left it a bit bend and the rubber foot pedal has come off but still does the job.
hard top
Dutch Zeds
Netherlands
Yep. air and water is free over here at all garages, you only have to pay for nitrogen.
TitanTim
Methane if I'm feeling energetic :(|) otherwise a foot pump :ymsmug:
Tim. s:lol
Aceman
Moderator
Wakefield
///M Roadster
I've got one of them too bought it about 3 years ago when costco first started stocking them paid £25 which was an absolute bargain when everywhere else was selling them for £50+. works really well and mine has a built in lamp so you can see what you are doing in the dark, inflates tyres really quick and is quiet too. I do use a seperate digital guage for checking the pressure although the analogue guage is pretty accurate. Well worth the £30 they are now. :-bd
Jamezee
Peak District
After carefully considering the options, I have today put my hand in my pocket and invested in a £26.99p halfrauds plug in with a illuminated digital display and .....wait for it....a built in light B-)
I could not wait to try it out in the dark so i did.......and all pressures were ok!....bit of a 'let down' ...I wanted to hear the thing pumping away but it was not to be.
Now where is that bouncy castle 8-} 8-} 8-} 8-}
