#ZedShed Krispy Scottish Zed
Lee
Z4 Coupe 3.0si
So this Zed came in for a quick n dirty but once up in the air we realised this needed a lot more love. Long story short she’s spent most of her life in Scotland and I’m guessing somewhere near the coast, I don’t think I’ve seen this much corrosion on a 70k mile car.
So we don’t waste the time not doing the quick n dirty we prepped the car, removed all the crispy bolts and even fitted a new diff bush.
Diff bush
rear
front shocks are a new record for me. How these pass an MOT every year is mind boggling.
So chatting with Billy abs we decided to do the quick n dirty but also replace as much as we could in a short time. Today we made a good start.
Old beam bush, turning into a flower =((
fresh new Meyle
we have some heavy corrosion in places
Blows my mind this is 70k miles. We also replaced all the rear brake lines. Old ones were all goosed
Ready to go back in.
Hopefully close of play this weekend we should have addressed the main mechanical issues. Will then look to sort the oil leaks.
@Lee
Thats what half the cars i am under for Mot look like up here that are a lot newer than our zeds.
Failed a hyundai i20 couple of days ago 14 plate fuel tank rotten leaking fuel
Brake pipes at rear rotten
Front suspension arms rotten round the bushes.
Weather and winters here harsh on cars im afraid.
  • Wow
Reactions: Lee
Crikey. And I thought mine was crispy. MoT man always comments about how crispy my bits are. I thought I was some kind of crispy-rights activist.
After seeing the beam and trailing arms on that one above I'm thoroughly demoralized. May as well get my wire brush out now. Bah!:mad:
  • Haha
Reactions: Lee
NabsNabsNabs
Epsom
2.2L Sport
I knew she wouldn't be great under there but I didn't think this bad!!
Looking forward to coming down tomorrow to see in the flakey flesh and optimistically hoping that rust always looks worse in pics than in reality!!!:rolleyes:
2.2 & 3.0 Sport
Is this one worse than mine Lee? Be good to pass that baton on:whistle:=))
  • Haha
Reactions: Lee
Lee
Z4 Coupe 3.0si
Today was a solid effort all round. Two full days to get this Zed up together. Will still have a fair few advisories once the MOT is done but least it won’t feel unsafe to drive.
First job was coating lots of rusty bits in K-rust to at least slow the process down. Then we refitted the subframe and hang her on new Sachs shocks. We also have new brake lines front to back.
next we fitted the prop shaft and shield
Last few jobs on the rear, first one fitting new rear drop links. Made me laugh getting these apart
Only the brake to bleed at the rear now so I moved to the front. This needed new tie & track rods along with shocks, we also did new callipers up front too.
Never seen shocks like that before.
Much better now
Couple other little jobs like replacing various tabs so we can fully attached the undertray
End of the day I finally did a test drive and she’s so much better. Just MOT and tracking now. She’s now at least safe to drive but still on that long road to recovery.
AntStark
2002 3.0 Sport
Another one that looks amazing above the water line..it must be a Topaz blue thing 😁
Can’t believe the last MOT didn’t mention the shocks once.
They should have just stopped here with the advisories . 🤣
NabsNabsNabs
Epsom
2.2L Sport
I am hoping all Lee's efforts and all the bits Kurust touch ups yesterday will get me a slight upgrade come testing day🙏
You could apply that comment to many older vehicles, including Z3s and possibly Z4 too as the vast majority aren’t owned and run by enthusiasts. The only variable is the amount of corrosion.
  • Agree
Reactions: Lee
Scooblitz
Glasgow, Scotland
Diff bush
rear
fresh new Meyle
Extra Crispy. Must have been battered and deep fried. Us Scots. 😉
  • Haha
Reactions: Lee
Lee
Z4 Coupe 3.0si
Did the last few jobs today. Rocker gasket being the main one, she was very leaky. I also fitted a new Ariel grommet and she’s now got a fresh MOT.
Every car tells its story when you have a peak inside. You can see this car has had some time sat around. Just look at the rust on the cams.
Also dug out some large chunks of old oil. Again a sign that it’s had big gaps between its servicing.
After giving everything a clean she was ready for re assembly. If your eagle eyed you’ll see my trick for keeping the rocker gasket in place so it don’t fall
With cable ties on they’re easy to snip and pull the long end out. Nice n easy takes 30 seconds to do.
Car is now ready for collection. She drives really nice now, done a fair few miles now so I’m happy she’s ready for the road again.
AntStark
2002 3.0 Sport
He tells us this trick now! 🤣 Everyday a school day at the shed.
  • Haha
Reactions: Lee
MuttyMax
Woking, Surrey
1.9 M44 and 2.8
Was the leak discovered before or after Dino's car spent some time under its Scottish cousin ? :whistle:
Dino D
Kent
2.8 Manual
Finally after years of study and on high level projects @Lee has leant some proper engineering and introduced cable ties to the his work
Wait until you see the wonders of stainless steel ties…(seriously useful for hold an exhaust up when the hanger breaks!)
I’ll happily sit on the board as ‘Chief Cable Tie Operating Officer’ (CCTOO, even has a nice ring to it..)
