Afternoon folks, I'm getting the check engine light, drives fine so figured its the O2 sensors. This was the case when I used to own an E46 330Ci. Same engine as my Z3 3.0 so guessing its same problem. Went to my usual garage to read code and comes up with "fuel trim range exceeded" on both banks so I'm guessing that is O2 sensor-related. The voltages on the pre-cat sensors take time to settle so I think I just need pre-cat sensors. No noticeable air leaks between intake, MAF and engine and the car is at 94k miles so I'm almost 100% sure it's a sensor problem as this is around the time they are due for a change anyway.
Therefore, my question is: Where is the best place for decent sensors at a reasonable price? I went on ECP and they only appear to have bank 2 pre-cat sensor and RealOEM tells me that the pre-cat sensors for banks 1 and 2 are different. Post-cat sensors are same part number. Might give SES a ring, I live in Southampton and there are only round the corner from me - got the others from them, for my E46, and price wasn't too extortionate.
Thanks in advance![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks in advance
