Before purchasing please check the installation notes. Reference the numbers below with the table HERE Fitting notes A,18,20 Eibach Pro-Kit Lowering Springs World's leading Performance Suspension Spring System. Engineered and tested to work perfectly with stock dampers. First step towards a...
To be honest I can’t remember what it was like on the standard springs it was so long ago and it’s been on 18s since 2016, there are lots of people using Eibach springs I’m sure someone with a better memory will comment.
The ride will also depend on the shocks, if the shocks are old/shot the ride will be bad regardless of the springs. Eibachs with good shocks IMO gives a firm but compliant ride, better than stock.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
