Jumped in the car today to nip out and was running really rough so cancelled nipping out and got the computer out.
Found that cyl 2 was not firing according to the diags so decided to lift the cover to inspect what was going on. The car was serviced a few weeks ago and hasn't done many miles since, on lifting the cover I was greeted with this:
Which shows the number 2 lead was not put back in its cable tray and has subsequently been crushed by the cover. I have swapped number 1 and 2 coil packs round, cleared the codes, in order to double check those and the error remains on number 2. The plug is nice and clean.
My question is, does anyone know if it is possible to replace the lead without replacing the whole harness as from the little inspection I did it does not look like a simple unplug old and plugin new?
I can only think that this is the issue unless anyone has any other suggestions?
Thanks,
James
![image.jpg image.jpg](https://zroadster.org/data/attachments/6/6293-a2a392bcfed5d9ee1d58ad78808eeb1f.jpg)
Thanks,
James
