Might as well start a thread and document what I'm tweaking on the Zed, since I already made a handful of topics about various bits.
Here's my Z, as I've got it. 2.8 facelift, 60k miles. It has 'unusual' leather it seems, all the normal goodies from the 2.8, the radio/cd was replaced by an Alpine bluetooth thing.
What I know needs to be done (in no particular order):
- Replace all bushings [with poly ones ?].
- Fix the seat safety belts mounts and springs.
- Refurb VANOS.
- Fix corrosion on the mount of the chrome rack. DONE; brush, greased etc.
- Change position lights -- one is borken. DONE; From new eBay set
- Change repeaters for clear; Done.
- New rear tyres; Uniroyal Rainmasters 245/40R17Y
- Change plates. Done. Might still remove the front 'mount'...
- Change lamps; the passenger side one is 'cloudy'; it's been cleared with t-cut, but I want clear indicators anyway. Done: @spurs fan in a coupe angel eyes installed.
- Replace all indicators with LED, with @5harp3y relay. Done!
- Fix seat bushes! [Done: driver; passenger one is OK]
- Clean carpets, check underneath for corrosion [Done: Underneath isn't too bad at all!]
- Change Fog lights -- one is borken: Done [Aftermarket from @spurs]
- Replace Rear lights for clear ones. Done [From @spurs]
- Fix corrosion under the bonnet, at the grills cutouts. Done (mostly)
- Updated worn badges. Done.
- Changed antenna grommet. Done.
- Clean engine bay. Done.
- Add 20mm spacers like all the cool kids! 10mm at front. Done!
- Change rear shocks and mounts. DONE [Thanks to #zedshed for the front ones!]
- Changed front lolipops. Done.
- Get hard top! [Thanks to @spurs]
- Converted all lights to clear (Front, Repeaters and back)
- Changed Alloy badges.
- Replace bonnet cable, due to garage bodge. [Done: Garage]
- Re weld the diff bracket (3 spot welds are gone). [Done: Garage]
- Replace engine mounts. [Done: Garage]
- Replace Control arm bushes with Z3M version. Done
- Rerouted the coolant overflow pipe like Z3M [Done: Garage]
- Installed @5harp3y Noise Box. Done
- Refurbished passenger mirror entirely. Done.
- Got 18" MV1 'summer' wheels!
- Refurb alloys -- done; both #18s and MV1s
- Refurb/Change rear brakes
- Refurb/Change front brakes for E46 300mm ones
- Replace Water pump/thermostat, idler
- Replace sills.
- Resprayed!
- New "chrome" front grills.
![](/proxy.php?image=http%3A%2F%2Foomz.net%2Fp%2Fweb%2F_1010557.jpg&hash=ea1d1182a3c885319c175312fa71ceef)
![](/proxy.php?image=http%3A%2F%2Foomz.net%2Fp%2Fweb%2F_1010551.jpg&hash=084bc83d8f6519470f608ee24a9b9647)
![](/proxy.php?image=http%3A%2F%2Foomz.net%2Fp%2Fweb%2F_1010554.jpg&hash=aaa5d54bacd27efd248eff58e48da76c)
