Steering noise
Keavo69
Newton abbot
Z3 2.8 roadster
Hi all
Can anyone tell me what this noise is it happened when we were driving back from Spain it only happens when it’s cold as I turn the steering left or right??
Sorry having trouble attaching video
A kind of scrubbing noise coming from the steering wheel? If that's what you've got then I've had it for quite a few years. Louder when it's cold.
Some say it's the UJ on the end of the steering column in the engine bay. Others say it's the slip ring behind the wheel. I suspect either of them could make a similar noise. I'll change both one day.
Keavo69
Newton abbot
Z3 2.8 roadster
Thanks for the reply
It’s more of a belt noise in the engine bay you do feel it through steering wheel though
Hi all
You can't upload video like you can still images. You have to upload to YouTube or similar and post a link to it.
Keavo69
Newton abbot
Z3 2.8 roadster
Hi all have a listen an tell me your thoughts
Cheers marv
Ianmc
Z3 (M44)
Says video is unavailable/private so can't access?
Cheers marv
It's set to Private so can't watch it mate. You need to set it to Public on YouTube..
the Nefyn cat
2.2i Sport
May be a stupid question, but do you have enough oil in the steering reservoir? And has the feel of the steering changed at all? If I remember rightly, there's a filter inside the reservoir, may be partially blocked.
Keavo69
Newton abbot
Z3 2.8 roadster
The car did have a health check recently and he did top up the reservoir I haven’t check since I came back so I will check the levels
Cheers marv
Ianmc
Z3 (M44)
If the fluid has gone down, good chance the cooling pipe (in front of the rad) is leaking.
the Nefyn cat
2.2i Sport
If it needed topping up before going to Spain then checking the level once you're back might be considered a good idea. These cars, being of the more mature nature, will need looking at more than newer stuff.
