Started the overhaul on mine and quite a daunting task it’s going to be looking at all the work that is needed and was quite disheartening to be honest but other builds on here are inspiring.
I’ve made a start on the rear. Rear boxes off, the dreaded 8mm cap heads loosened off with no drama probably all the wd40 soaks have helped. Everything loosened off ready for the rear beam drop. Hit a hiccup with the rear hub removal as one of the puller legs broke so that’s going back to Amazon and looking at an alternative. As I packed up for the day I realised I’m going to have to remove the Center of the exhaust to change the hand brake cable. Good excuse to change the prop shaft bearing carrier and gubbo while I’m at it.
Must say the Makita impact wrench has made the job a lot easier. Hub nuts spun off without a sweat.
I think with what I want to do I don’t think I’ll have it back on the road for about three months. But I’ll think I’ll get the rear beam, trailing arms and maybe hubs blasted to reduce some of the prep time.
