Very stiff driver's window
Z3 project and E89 Z4
Hi my driver's window is struggling to open the last third of it's travel. It's OK on the top two thirds of travel. The further down it goes, the more it labours. I am worried it will damage the motor, or take out a fuse.
Is there any known tips to help free it up? I have loosened the bolt on the underside of the door which holds the retaining channels, so don't think it's that.
There is nothing in the way (I did check that I haven't left a rag or something in there). It seems like the glass is slightly fouling on something.
Any tips or ideas most welcome.
Jam03
Surrey
2.2i
I was amazed that spraying a bit of silicone spray in the channel on the quarter light freed my window up, but it’s not the only factor. My window is sticky again after about 6 months.
I have loads of Gummi-pflege type stuff (as I have a Z4 and have had other verts in the past). Problem I have is I dare not put the window all the way down as I don't feel confident it will come back up. :nailbiting:
mikeyH
South Devon
2.2 Z4 E85
try some silicone spray on the rubbers that surround the glass, do it both sides.
Had the squeaky windows on my Z4 E85 and someone suggested silicone spray, worked a treat. Might just be very dry and unable to slide.
