A 1999 Z3 2.0 write off has been well and truly burgled.
Silver drivers door mirror in very good condition, one tiny bit of corrosion on the base at the rear where you can’t really see it, £90
Passenger mirror as above but the base is quite corroded, not seized £60
Complete black roll hoop kit with all screws, bolts etc £250 collect only.
Door pulls in excellent condition £90 each.
Aeriel base unit in amazing condition £80
Two almost new rear springs £40
Rear calipers, perfect working order £60 each or £100 for both. Complete with brackets and recent new hoses. Postage £10 UK mainland.
Passenger side rear trailing arm for all wide body cars, very good condition complete with handbrake cable, disc etc £200 collect only.
Rear tilt switch in boot, pretty much like new £50.
Other parts - wide type switch blanks, throttle body M52TU 2.0 and 2.8, engine mount arms, idle control valve, ABS pump (ASC type 896 897) fog light double switch.
Location SHEFFIELD.
Location SHEFFIELD.
