So I know Tom has been posting his EV conversion up here but since this type of project is likely to become more common I thought I'd give you my take on it
I've been a petrol head forever and this is my first EV conversion but in the past I've done lots of engine conversions and general modification including
Rover V8 into Ford Capri, Turbo 2l Capri, Fiat X19 turbo conversion, Individual throttle bodies, rearmount turbo and Air ride on my Nissan 350Z any way you get the idea
so this is my car a 99 2.0l manual in topaz blue
The conversion will use the Nissan leaf em57 motor and inverter with an open inverter control board and if I can squeeze both in 2 BMW 530e battery packs Battery management will be a modified version of SimpBms and the charger is from a Volvo (not sure which one) since this started out as a conversion of a Mini Cooper S much of the development work around the electronics has already been done and is mostly unaffected by the change of donor vehicle so far I have concentrated on the bodywork as the side rocker panels (cosmetic outer sill) were a bit worse for wear though the structural sills underneath were excellent with very minor rust these have been replaced
I had to take this back to bare metal as it had been poorly filled so was easier to start again.
and there it is all ready for the conversion to begin
