A new tool
Southernboy
Anyone guess what I made this tool for.
It can be used on BMW models other than the Z3, but I made it specifically for use on my Z.
It is made from 5mm x 25mm x 150mm mild stell.
It would work equally well if it was 3 or 4 mm thick metal too. Anything less might be a problem.
The gap in the ends are 5mm wide x 30mm long, but the length is okay at 20mm.
I made them that long to ensure I didn't have any issues.
Overall length can be as little as 140mm...
The ends are bent at aprox 10 - 12 degrees and the bend is 55mm from the center - so 110mm between the two bends.
The nut is a 16mm, but a 15 or 17 or 20 will be good too.
Hint - fuel supply
Injector puller?
A puller to get your wallet out when you have to pay at the fuel station Barry =))
Southernboy
Close !! but not that.... Yes, moths fly out when I open my wallet...=))
Southernboy
Okay, so it's actually a type of spanner for a specific fitting. both slots engage in the item to loosen or tighten it...
Mazza
Bognor Regis
To remove the sender unit cap from the tank?
Southernboy
BINGO !! Well done.... Yes - it's exactly that- a spanner for the plastic securing ring to remove the pump / sender unit.:thumbsup:
Mazza
Bognor Regis
I cheated.......I’ve got a spare tank in the shed and went and measured it =)):whistle:
Southernboy
At least your mind was in the right place....... Yes, a screwdriver and hammer will work, but it does damage. Also, after replacing the sender ceramic card and using the hammer method, I ended up breaking the new card and had to replace it again, At 25.00 excl postage, that's a stupid waste. The spanner cost nothing except a little time and effort.
