Who did you get to do all that for you then Ant? Eh,Eh.![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Looking very nice mate. The old units look pukka but a modern one is more useful really. I can't quite make it out, is it a Sony unit?, that's what I had in mine.
Crikey that was a bargain for the head unit AntFinal took the plunge to change the headunit in the car.Had the stock bmw business cd player but thought that the system may sound better with a more uptodate unit and add bluetooth etc.
Found a head unit local for £25 a bargain really has all the features i need so after getting the correct loom so i could use the hk system still.
Fitted well and has made a difference in the fact the sounds alot fuller and can now bluetooth stream .
Got some acs plaques for the floor matts just a simple touch but as they are quite substantial and bolt through they look quite well. Have the pedals to match on order and then the inside is nearly finished.
Theres quite a few around when you look Steve they are alot cheaper now than they used to be ...bargains to be hadCrikey that was a bargain for the head unit Ant.
Liking the plaques on the carpet mats,they compliment your new sill trims and your interior is looking top drawer mate,all very tasteful.
Steve
I think thete is a little more room on the left in an auto jim my foot only just goes past the clutch pedal so not a lot of room / point to it really ...If you check back @t-tony installed the footrest in his z3. I believe he slit the surround and added an aluminium strip to make it work. I intend to do this also so may be worth looking into before getting rid of the footrest. JIM
I got mine from BMW Germany. £50 delivered.Just a gear stick surround to add when southern boy completes them and thats the inside done.
Short of may be a full speaker refresh..![]()
