Day 3
fit new handbrake cables to the car end, very easy, just press them in by hand and then attach the cables in the car
press in your new shiny poly bushes by hand and put everything back together.
first also install your Revshift diff spacers and studs, this should help reduce negative camber by 0.5%
get it back under the car and prepare to wrestle with it for an hour or so
BUT THIS IS WHERE THE PROBLEMS STARTED
in the first post i said i have the job half done.
well
it would appear that Hack Engineering very accidentally sent me the wrong bushes to do this job and what you see are Revshifts E30 rear bushes ... which aren't compatible with our Z3's
this is a bit of a watchout, even though everyone says the Z3 uses a E30 rear end there are fundamental differences in how they are mounted.
the mounts are very different and as such the e30 ones are too long for the z3
so long story short, the car is still on axle stands, Revshift are sending me out a set of new bushes this week via UPS
massive bummer as i really wanted the car back together this weekend. but hey ho ... we live to fight another day.
well
