I think it's time that I do a progress thread as I've got posts scattered everywhere on the forum and no real recollection of what I've done or when it has been done.
I'll start from the beginning.
In August 2015 I passed my driving test it was time to buy a car, I had the Z3 in mind and was looking at something in the £1000-2000 range, I saw all sorts on auto trader and wanted a Z3 fast, I was considering high mileage cars, some with over 150k miles but thankfully my dad stopped me and he found for me a lovely 1.9l Z3 with 60,000 miles on the clock. Car was clean with little or no rust on the body, previous owner purchased in 2013 for £3000 and I picked it up in August 2015 for £1800 - BARGAIN (or so I thought)![Rolls On Floor Laughing =)) =))](/assets/rofl.gif)
My mechanical knowledge was limited when I bought the car as I'd never been interested in the actual mechanics of car until I bought this. In fact I'm pretty sure that my dad had to point me to where the windscreen washer fluid was!
Here are a few pictures taken of the car on the day
We bought the car from Merseyside and dad actually drove it back as I had no motorway driving experience at the time.
All was good on the way back in that nothing blew up and the car didn't break down but there were a few problems:
This was meant to be a fix for the soft top leaking - needless to say it didn't work for very long.
Not knowing much mechanically I took it to a garage to have them look at why the car was running so rich and so came my first garage bill:
Bill - 07/09/15 - £213.65
Less than a month later, the whining noise was driving me nuts so I bit the bullet and took the car to the garage and they were shocked to see how corroded the brake pipes were. They also addressed the third brake light not working which was down to the loom having split in the middle, this was soldered back together and covered in heat shrink tubing if I remember correctly.
Pictures of brake hoses & pipes - all perished!
Bill - 02/10/15 - £356.56
Bill - 24/04/15 - £12.99
Around Christmas I treated myself to a set of twin exhaust tips from eBay...
Bill - 21/12/16 - £15
In January 2016, I'd had the car for a few months and with the amount it had cost in garage bills to keep the car running any normal person would have sold it there and then - however, I'm far from normal, so I stuck with the car - fitted the plugs myself but didn't fit the fuel filter until the end of the year with help from @t-tony
Bill - 14/01/16 - £22.47
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Bill - 19/01/16 - £75.27
Bill - 11/02/16 - £31.78
Late February I fitted a K&N Induction kit to the car - no performance increase noticed - sounds a lot nicer though:
Bill - 25/02/16 - £91.80
Next came a few good months of zedding and by good I mean, money free!
Except fuel of course!
I needed a drivers side floor mat but couldn't find any originals in good condition, so I bought a pair of mats from eBay. When they arrived some of the stitching was poor in quality so I sent them a message to complain and got a full refund and got to keep the mats!
Bill - 03/06/16 - £24.95 - but refunded so £0.00
However, MOT was costly - there was an advisory the previous year of slight play in ball joint and I thought to replace both control arms, I did the O/S myself but it was so tedious with all the rusted bolts that I gave the garage the arm to fit on the N/S, also needed two near front tyres as the old ones were perished and had cuts in the sidewall. Went with Pirelli P7's - not cheap at all!
Bill - 10/06/16 - £431.60 (MOT, Tyres and fitting of the supplied control arm)
Bill - 25/05/16 - £127.45 - Febi Control Arms and Wishbone Bushes
Bill - 08/06/16 - £12.24 - 2 x Stabiliser Links
The rear window was certainly showing its age as the stitching had started to come apart. The soft top had also shrunk where it met the A-Pillar.
So it was time to get rid of the old and get a replacement fitted!
Bill - 07/07/16 - £550
I was hoping this would cure the leak, it didn't, the car would still let water in from the A-Pillars and this drove me mad.
A few days after the new roof, it was time for a full body polish -
I thought this would be a good idea as a lot of things go missed and don't get documented. I like having something to refer back to when I want and I know it also makes a good read for some.![Thumbs Up :thumbsup: :thumbsup:](/assets/thumbs_up.gif)
There's lots more to cover, but I'll do that in the post below.
- 3rd brake light didn't work
- Masses of water leaking into boot
- Soft Top leaking
- Annoying whining noise coming from somewhere and the noise could be heard usually on deceleration
- Fuel consumption excessive - 12-15MPG
- Camshaft Sensor replaced
- Split breather hoses under inlet manifold replaced
- Emissions correct after clearing error data
- Handbrake shoes and cables replaced
- All brake hoses and rear brake pipes replaced
- Third brake light gasket replaced and sealant placed around the gasket to prevent water ingress
- Soft top release latch lock screw seized - replaced
- Exhaust Tip
- Have tip welded on
- 4 x Bosch Super Plus Spark Plugs
- MANN Fuel Filter
- Replaced both strut top mounts
- K-Seal Cooling System Repair
- 5l Red Antifreeze
- Triple QX Screenwash
![Mozza :ymalien: :ymalien:](/assets/alien.gif)
