Finally got the wiring for the heated seats done today, took just over a week - on and off of course but unfortunately faced a few annoying issues along the way.
Drivers side heating element both the base and the back had burnt out.
Essentially a lot of burnt wires. New wires put in and buried into the foam.
Hog rings were an absolute pain so went with heavy duty zip ties instead.
Also faced issues with the fabric that needed stretching back into the metal clips under the seat. The fabric had started to tear in places so had to stitch it back together.
Changed the bushes whilst I had the seats out and original bushes were in surprisingly good condition..
Then had an issue with the seats going forward when clicking on the backwards button and backward when clicking on the forward button.
View: https://youtu.be/T8seafT365c
I couldn't figure out why this was happening but in the end I swapped the physical position of the motor - unscrewed it and flipped it around. This fixes the issue and the seat now goes forward when you click the forward button and back when you click the back button.
Unfortunately I felt like the motor was failing because it was getting really hot after a few tries and would stop moving, luckily I had a spare motor that I was able to use from an old seat!
Fitted the seats back in this evening and it's looking really good.
Let's hope the heated seats stay working as I don't have the energy to do this again!
Bill 15/10/17
Heated Seats Adapter £~90
Soldering Iron - £7
Solder - £1.65
Flux Paste - £5
Heat Shrink Tubing - £5
Bushes - £7
Total £115.65
I think next will be my brakes but I think I deserve a 'break' before I start.
wow.... I'm exhausted.
Faheem
