Cheers Tim - its amazing how the small things can make a big difference to the look of the car. I was sceptical about the positioning of the front one for a while and played about with it but having been out today I came home and surprised myself by catching a glimpse of it parked on the drive and the position looks perfect.
Anyway, managed to get another few bits done today..
FIrst of all I have managed to install the wiring for the foot well lights I bought from littlefeller 2 years ago. I had these in my 2.0l Z and they are really effective and a load better than the horrible blue florescent tube that was there before.
The next thing I was able to do is wire in my new head unit and test the rewire of all my speakers and the DAB aerial to ensure they are working, unfortunately to do this I have had to reconnect the battery and turn on the ignition which means I am going to have to find my airbag reset tool
![Bang Head :banghead: :banghead:](/styles/default/xenforo/smilies/banghead.png)
but I thought it would be better to test this out now with everything out rather than finding out that it doesn't work after I have hidden all the wires behind the dash. Thankfully everything seems good and there is sound coming out of all the speakers. I do think that the subwoofers in the footwell are going to have to be changed as the one on the drivers side seems to be popping a bit so I might just disconnect it for now and see how it sounds.
Finally this evening I have been able to reassemble my new dashboard ready to be reinstalled tomorrow. The hardest part is putting the dial dome back together as BMW have designed it in such a way that it should never be separated. The whole thing is held together by pressure in opposing directions and then the plastic is welded/melted together. When I separated the dash I had to Dremmel this bit apart so it was out with my new glue gun (the old one went pop yesterday!) and reglue all the plastics after spending about an hour trying to bend and manipulate the whole thing together.
With this done I could now start putting all the screws back in to hold all the parts together and then to start reassembling the air vents. After almost 20 years the foam around the vents had all but perished and gone (probably blown out into my face over the past couple of years!) so I used some draught excluder seal stuff to recreate the seals back to "as new"
Unfortunately the dash I am now installing is missing one of the small pipes that carries air to the 2 little vents on the top of the dash. Having swapped the dashes on my old Zed I was aware that BMW changed the underside of the dashboards so I couldn't just use the parts of my existing dash so it was into the garage to find a piece of washing machine hose and some gorilla tape....
and then with all the vents now assembled the dash is pretty much ready to be fitted into the car tomorrow..
![](/proxy.php?image=http%3A%2F%2Fi42.photobucket.com%2Falbums%2Fe309%2Fbertiejaffa%2FIMG_1652_zpsmjw3fskh.jpg&hash=81839ae68f6bd6ea8667aee2da8933a2)
