- Oct 19, 2014
- Model of Z
- 2.2i Sport
Due to the way the suspension works fitting a 10mm pad will lift the car somewhere around 20mm, and if your beam bushes are knackered that'll influence things, too. It ain't meant to be easy.
You can only really spring pad up the rear but -30 isn't too low, the frontonly really carries the engine weight so little movement adding weight.The rear will alterwith two people and a boot full so adding spring pads in the rear will improve things.Good info. So if I went Bilstein Pro Kit with the -30mm springs and added 10mm spring pads, that might be about right for the pothole roads? Would it be the same size pads all around and where is the best place to get them from?
Thanks. I’m also replacing all bushes.Due to the way the suspension works fitting a 10mm pad will lift the car somewhere around 20mm, and if your beam bushes are knackered that'll influence things, too. It ain't meant to be easy.
Got it. Thanks again!You can only really spring pad up the rear but -30 isn't too low, the frontonly really carries the engine weight so little movement adding weight.The rear will alterwith two people and a boot full so adding spring pads in the rear will improve things.
Bmw are as cheap if not cheaper than most places they are not expensive.
As posted above you add the pad at the midway point on the arm so the actual lift you get is greater than the pad you put in, i would lower it and see what if anything you need to do.
Mines -40 and i have only caught it once or twice and its not bottomed out its more that if its a sharp bump the suspension travel back down creates a bounce so driving carefully helps![]()
anybody know what is the thread size on the top mount of the bilstien b12 pro kit 10mm or 12mm?
