Sitting in a car park after going for a run in the 1.9.....and contemplating how I will tackle all the problems on the 2.8.
Exhaust off first.... I have a multitool with a metal blade.... so will cut all the remaining bits of nut off, I have a blowlamp, so can heat the flanges and I have a big G clamp and socket... so thinking positively.... that will do it. !
Probably best to support the weight with axle stands until the flange is separated.
The snapped brake pipe will need to be repaired, so will need to get a flaring tool that will work in situ and some new fittings The other side brake union is totally rounded so will cut that and do a similar repair. So no problem there .....
Once I have had a bit of a practice !!!
the screws of doom......I have found a impact driver.....( forgot I had it, )... So space permitting, I can put a slot in the head with the multitool, and whack it with a hammer ......Theory good .....
If they undo great !! But if the head snaps off no worse off and at least I will be able to drop the beam
broken stud in front cross beam......use my angle grinder (very carefully) to even up the end of the stud, then centre pop it, drill a 3 or 4mm hole down the centre and use an extractor which I will have to buy.... that’ll work
If all that goes according to plan.... just need to persuade the diff bush nut and bolt to undo or cut it out
Then Other than a heat shield and the hand brake cables to release, every thing else is ok
....someone doesn’t agree....I’m getting negative vibes....
![Arghh :arghh: :arghh:](/styles/default/xenforo/smilies/arghh.png)
So that’s the plan..... and it springs into action on Tuesday
Now off to burn some fuel needlessly
