Good stuff
i thought mine would rexord more than it does i have just reduced the res. To get it to record longer.
That will last around 36 hrs on constant record if you turn the resolution down. But the dash cam should override the first clip when full, either 2 minute or 5 minute intervals depending on the dash cam.Just got a 32 gb card, thats the biggest it takes so I'm assuming it will hold quite a bit mate
I run my 32g all day when driving and it never over writes and is set to 1080Thats what i got for mine a next base camera but it eats data from full format @ 1080 it its just over 1.5
hours before it starts to rewrite over itself.
Yes just looked on mine and it has 1-3-5 minute intervalsThat will last around 36 hrs on constant record if you turn the resolution down. But the dash cam should override the first clip when full, either 2 minute or 5 minute intervals depending on the dash cam.
Mine can either be 3 min, 5 min or constant record.
Also depends if it has gps for logging purposes as you can download software to access where you have been, i am not sure of the names of them as i use the specific one for the Dodd Dash cam
That's mostly what they have on them Sean.Yes just looked on mine and it has 1-3-5 minute intervals
