You can do it without removing the spare wheel5 minute job 1le of castrol syntrax 75w-140 remove spare wheel as long as car level just 2 hex nuts ...dont be tempted to over fill
Hi Tim, I can't see a sticker on my gear box, I have a 2l no slip diff, what oils would you recommend for both diff and boxAlthough it's a manual, it needs an ATF fluid and the best options are the Red Line D4 or Fuchs ATF5005, although the others are fine as cheaper alternatives.
http://www.opieoils.co.uk/c-771-dexron-iii.aspx
Cheers
Tim
99 faceliftHi
What year is it?
Cheers
Tim
Confusing stuff !!! ATF for a manual box and gear box oil for the diffHi
ATF for your gearbox as well, then you need a 75w-90 GL5 for your diff.
http://www.opieoils.co.uk/c-673-75w-90-mtfs-manual-transmission-fluid.aspx
The Fuchs Syn 5, Millers CRX, Red Line 75w-90 GL5, Motul Gear 300 and Gulf Competition are ideal for the diff. The Fuchs Sintopoid, Castrol Syntrax Longlife, Millers TRX, Motul Motylgear, Mobil SHC and Gulf Syngear are also good choices.
Cheers
Tim
I am now a bit puzzled as just about to order both but Tis sheets show for my 2.2Hi @Davyhoogy apologies I forgot I said I would post some info after I had done mine.........i did but on my progress thread "made a start today"..
Gear box oil 2 litres Redline D4 used 1.5 litres approx. Has made gear changes smoother and the box quieter.
Diff oil 2litres Castrol syntrax 2 litres and it took just about all of it.
Got mine from @oilman Opie oils.
Hope this helps.
Steve
Sounds interesting, care to share a link to what it is you bought?I also forget to mention, that doing the earls braided clutch hose is the best thing I've done to my Zed , it stops that oem hose expanding every time u push ure clutch in , and also it gets rid off the clutch delay valve, mine was sometimes really really notchy, not no more more, it's like like silk now, iff I had to do it again though , I'd pay a good mechanic to do it, as u need brake flare spannes , pressure bleeders to rebleed the system , and it's a bi*** to bleed tucked up in the gearbox tunnel, ohh I'd love a four poster ramp
Great I'll look into it thanks, but as you say seems like quite a bit of work with bleeding etc. Although the results sound worth it!Here u go, earls performance prouducts,01327 858 221 they'll make u one up specific for ure car , and only £25 ish, and delivered a few days later.
