Amazing work guys, love reading these updates, @Dino D you are getting back one special Z3...
probably blew off on your drive home with amount of miles you did just to get it there!
Legend MalcYou mean one of these
check the post next week, I’ll send you it.
I ‘acquired’ it on a visit to the Zedshed
Cheers mate. There’s still rubber bushes supporting the gearbox, it’s just the bracket is sat 20mm lower with spacers. I’ve got some ally plate on the way to replace the spacers for better strength. Really difficult to sort during a lockdown when everywhere is shut down here.Can't wait for you to check it out Lee, will be so pleased for you,Trevor and Dino if it turns out better than you think. Fingers crossed they'll be no vibes from the gearbox mounting. Hurry up and test it cos the suspense it worse than the weekly series on the tele at the moment.
Roy.![]()
Blimey it’s visits are every 5 years or so - could take a while if it takes a 3rd visit for a sticker....and then what will need doing? The only thing left to swap out is the engine...or bolt on some forced inductionDino, it also took me two jobs in the shed to get a ZedShed sticker![]()
I actually looked at that gearbox first but it’s not compatible with the M52/M54 platform, unless you really want to hack it apart and customise every part.At last maybe the Z4 fraternity have something the Z3 people could really do with, not talking engines here which of course are better in the Z4sjust the plain old 6speed gearbox. Can't be a bad argument at long last.
. Looks are not everything, ask the northerners.
RHA,Roy.![]()
Pass mate without checking them all I couldn’t be sure. I didn’t use the M3 6 speed box because they cost a fortune. Least with this gearbox it’s affordable and only needs a few tweaks to get everything to fit.I have been looking at 6 speed gear boxes and read about the different pilot bushing being in the flywheel on some. Is the input shaft the same on all E46 gearboxes from the M3 with the pilot bearing in the flywheel?
The E46 box is just more common then then the 6 speed from the E36.
Lee should end all his updates with the Eastenders drum sequenceCan't wait for you to check it out Lee, will be so pleased for you,Trevor and Dino if it turns out better than you think. Fingers crossed they'll be no vibes from the gearbox mounting. Hurry up and test it cos the suspense it worse than the weekly series on the tele at the moment.
Roy.![]()
