Watertight
(at last, I hope!)
So last summer I had lots of fun with Butyl and replaced the hood to body frame seal that runs around the back of the car.
I used 2x 8m by 6mm rolls of butyl sealant bought on eBay:
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/182375699393
I ran 2 beads of the stuff around the corners where it tends to leak most.
Worth noting my car had a new hood a few years before I bought it (will check the year, have the invoice) from Carhood wharehouse and I don’t think they used enough sealant which caused it to leak again as can be seen from the pics of the gunk left on the frame, it was not much especially in the corners..
When I get a new hood fitted I’ll be looking closely at what sealant the company uses as I don’t fancy a repeat of this job!
After a second attempt (because I originally only ordered 1 roll and ran short so got impatient and bought the tube style sealant to finish the job...which didn’t work so got 2 rolls and did all again properly the following weekend) it was water tight (or so I thought).
Funny note: my neighbour, also a car not rightly pointed out this Z is like the Forth bridge!
This winter I noticed I’m getting a lot of condensation in the car again???
I stripped the boot carpets and carpet begin hoops and check again carefully. Not a drop from the roof frame....
A pillars are all done and window seals were tight...
Luckily I had cut my floor carpets in sections to aid drying the car and chasing leaks so got them out again and found the leak...the bl@@dy door membranes!
The butyl had dried out a fair bit and the water was coming in from there (aided by a split in one of wing mirror base rubber seals, will get a new one..).
So I ordered more of the butyl roll and did both doors.
Top tip:
interior trim removal tools make getting trim off easy and less breaking if clips and also work well to remove old butyl:
I ran a double seal at the bottom where it leaks and used a heat gun to warm the surface before applying and then again to seal the plastic against the butyl really well at the bottom.
I actually then added gorilla tape over the bottom seal for extra good measure!
Gave the car a wash and no leaks!
I’m so used to a water leak of some sort I’m still in a bit of disbelief but I think I can safely say it’s dry!!
Managed a roof down run before the sleet came down!
![2A081A65-D14A-4127-B0BC-83038F8ADF80.jpeg 2A081A65-D14A-4127-B0BC-83038F8ADF80.jpeg](https://zroadster.org/data/attachments/73/73394-035e52179cd054112adea60120906836.jpg)
