The wet floor saga continues!
Since the floor is dripping wet both in front and behind the cross member that divides it, it seems reasonable to me that rain coming from behind the door trim panel is the most likely source. So I took the passenger door panel off and look what I found. Not only is there all that duct tape, but I see the membrane is cracked quite badly in several places. Someone has obviously been here before trying to fix the same problem.
It started getting dark so further investigation was stalled. How is the membrane fixed to the door? Is it glued on? Can I buy a new one? What should I do to keep the water inside the door from where it can escape through the drain holes?
