Second time for this to happen. Last time was about three months ago ago, and I have probably driven the car a few dozen times since then with no further problem. Symptoms are after driving and then parking the car and then returning shortly after a quick stop to pick up something at a local store in return of the key only yields a click from under the hood. The starter does not spin the motor. I give it a few more turns of the key and the same identical symptom every time just to click from under the hood so I checked both battery terminals to make sure they are clean and tight and they are,… The battery is only about six months old and has never given indication of not holding a charge. So I assume the problem is elsewhere potentially a failing starter or maybe a bad ground somewhere under the hood? Both the first time and when this happened again, a few days ago, turning the key back to off and then to start again about 50 Ish times eventually got the starter to spend properly and now all seems good with the car, but I am afraid to drive it in this condition For fear I might get stranded somewhere.
