But if Gaz only re used what came off in the first place , I would do the same to be honest. You can't realistically check every component to make sure all fittings are present and correct. I trust to experience, that's all.
Agreed Gaz, the trouble is someone, at some time or other seems to have replaced the original bolts, possibly because it's easier to do up an allan screw than put a socket on a nut in confined places. Any way the damage is done, the point i would make is try not to make the same mistake as it has quite possibly caused premature failure of the fan.But there were no washers on it previously, and that was an OEM fan blade and most likely the original. I'm not arguing for arguing sake, just wondering how the hell I'm supposed to figure out it needs washers if I'm not supplied any or diagrams don't show them![]()
5 is pointing to the water pump pulley...I think it is showing number 5 as the one holding the fan on.
Does it still need washers? The bolts I have are the same shape then, just that I have an internal hex, rather than torx.Right, done the research, it should be an internal torx cap screw
ThanksThe tightening torque should be 10Nm so not very much, this is just the flick of a wrist.
I'll be OK with a flick of the wrist!I have torque wrenches if you need them Gaz?
I'm not arguing that they shouldn't be there, just that I can't find evidence either way. I will use the washers I've trimmed down to fit in the available space when I refit - I see no reason not to!I'll see if I can find a car with a similar setup and have a close look tomorrow Gaz and report back. However i still maintain that this would not have happened if a washer had been used on each screw.
Moral of the story Gaz, you don't know your own strength mate !Mike, I agree, especially with a cap screw, if you look on real oem at the early 1995 cars, they did in fact have a washer. But it is really easy to over tighten these, and the substrate just cracks. The way they have all cracked I the same way demonstrates the over tightening. This is the reason the dealer wanted to go through a warranty claim, the investigation would have confirmed this and no claim would be paid, we review them daily, so fair play to Gaz for pushing for and getting a new part.
