My pleasure, your zed is getting a great overhaul, well done.@spurs fan in a coupe, (don’t now how to attach members yet?) thanks for sourcing me the: screen washer bottle, centre vent and headlight switch! Got the new washer bottle in today which is sweet. Previous owner had left me a little surprise regarding cracked washer bottle with a bit of silicone to botch job until sale. Thanks, couldn’t find one anywhere!
I like your broom idea, it seems my idea isn’t totally working as the fluid is slowly draining out the rear left@ZedHead for your brakes, you need to find something to press the pedal in the car (I used a broom) if you do that the fluid will NOT drain and you can do cutting and replacing of stuff. Do not let the fluid drain, as it will requires unknown work to re-prime the ABS pump...
Bush, good info but you kept me up last night, i saw the ziplock bag slowly filling with brake fluid and then had a vision of having to do the re-prime work, stopped by the petrol station on the way home and bought 2 bottles of dot 4 after having bought another bottle which will only get here tomorrow through amazon so . . .then got hame and the fluid had only drained to min line . . .good save peeps@ZedHead for your brakes, you need to find something to press the pedal in the car (I used a broom) if you do that the fluid will NOT drain and you can do cutting and replacing of stuff. Do not let the fluid drain, as it will requires unknown work to re-prime the ABS pump...
Top marks for effort....deleted previous post as not what you wanted .....![]()
