Spoken by a true roughneck ![Whistle :whistle: :whistle:](/assets/whistle.gif)
You heathen we do things in a controlled manner!![]()
Glad to see a happy ending after all that![]()
Z3 Bearing Removal
youtube.com
I have helped do this on my trailing arms….. but only as ballast to hold the arm down.![]()
Mine was at the very other end of that spectrum... zooming in lustfuly at the underside of low mile z3s with minimal rust...
To be expected all considered and living to tell the tale.Mine was at the very other end of that spectrum![]()
@paranorz Picture 10 illustrates what I believe is your issue. Middle, below trailing arm.Kicking off the new season in the shed we took in Gina’s 3.0. It’s a 51k mile 3.0 with exceptional history from the island of Jersey. The biggest benefit of this is they don’t salt roads out there so it’s going to be very clean and lacking corrosion.
Quick walk round. Just some nasty badges and very stock wheels.
View attachment 286673View attachment 286671View attachment 286669View attachment 286675
we also noticed the typical rocking seats and both door cards lacking in handles.
very low miles
bay not been cleaned in a very long time, also showing off our new engine bay light.
looking underneath and it’s so clean
such clean arms
front is just as clean
typical totally shot beam bushes offering no support. There should be a finger sized gap between the plate and bottom of bush.
stay tuned for the next big update. She’s already stripped.
Not sure i have the talent for dropping out the whole rear subframe, might have to look into how much all that will cost done by a pro.@paranorz Picture 10 illustrates what I believe is your issue. Middle, below trailing arm.
The rear beam subframe should sit above the chassis plates but due to bad bushings, it has sunk around 1 inch or more.
This is why your car is dragging its bum over speed bumps, not because it's on 18s or primarily because it's lowered.
All Zed Shed build threads are almost a diffinitive guide to sproosing up your z.
Scooblitz
PM @Lee - if you are Southern England, why go anywhere else?Not sure i have the talent for dropping out the whole rear subframe, might have to look into how much all that will cost done by a pro.
