Could be interpreted as imitating a police car - red sequenced flashing lights. Not that they use Z4's but the effect could be interpreted that way.I can see you getting a pull for that Tony .
Even though to the letter of the law the high level stop lamp not part of mot .
On a lot of modern cars the brake lights flash when the vehicle abs is activated to warn drivers behind vehicle is doing an emergency stop.I thought if you braked hard with a Z4 the brake lights flashed anyway![]()
Any kind of flashing red lights is a big no no.I would maintain that if it gets the attention of an approaching driver before it hits you then it can't be a bad thing. You see cars with no front number plates and obviously mis spaced number plate letters etc. and till they get an automated system to send you a pre determined fine through the post for a light out I'll take a chance. At worst I'll get a "producer" and a visit to a testing station to get the ticket stamped. Its not a hanging offence.
I quite fancied one of these until I read your post, think I'll give it a missAny kind of flashing red lights is a big no no.
Defect forms and "producers" are a thing of the distant past. If, you are unfortunate to get stopped by a cop with any sort of interest in traffic, you'll be given an offence report form and then someone in an ivory tower will send out an offer of a fixed penalty at £100 or the offer of a court appearance.
It’s the hazard flashers not the brake lights isn’t it?On a lot of modern cars the brake lights flash when the vehicle abs is activated to warn drivers behind vehicle is doing an emergency stop.
It is on lorriesIt’s the hazard flashers not the brake lights isn’t it?
And that, is the point I make Keith. Regarding number plates, photographic evidence would prove non compliance with regulations. but my feeling is it's more trouble than it's worth, so the Authorities place the onus for Policing that on MOT testers and then they do not back them up. Cars are common place with illegally spaced number plates (look at cars on here?) and also cars running with no front number plate. If you have a dash cam tell me what you see when following a car with the 3rd brake light on, what you see is a flickering row of lights when you download the video.a cop with any sort of interest (or knowledge?) in traffic,
The only reason the video looks like that is because all led pulse ( you just cant see it with the naked eye ) camera picks it up because of the frame rate.If you have a dash cam tell me what you see when following a car with the 3rd brake light on, what you see is a flickering row of lights when you download the video.
Vauxhall it's the brake lights.It’s the hazard flashers not the brake lights isn’t it?
Can you point me to where I can read this for myself Keith please? Regarding the MOT Test, if the 3rd brake light does not work then it's an advisory item, not even a failure.Any kind of flashing red lights is a big no no.
Exactly the point I'm making Steve, cameras don't pick this up, they just show flickering lights. How is this proved then?The only reason the video looks like that is because all led pulse ( you just cant see it with the naked eye ) camera picks it up because of the frame rate.
Absolutely Steve, this is, and always has been the problem with the disparity between regulations and the MOT test. Most Police Officers out on the road do not know the MOT regs. but they can try to prosecute drivers on a different set of rules that they THINK is right.On you video the high level flickers ( but that is only on the video ) to the naked eye it doesn't.
As you are fitting this to the high level lamp ( as a still active mot tester) it would be an advise .
Just to add a comment ( to keep things right ) on your post above ( extract from mot manual)
There is a second part which also comes into play
The section on switching does say they must come on immediately View attachment 126451
That in conjunction with the steady red light would make it a fail if attempt to fit to the 2 mandatory stop lamps
Like I said the high level would Not fail for this as it is not classed as a mandatory lamp
What the police may say about it is another matter all together ( as I do not know if that would contravene the road traffic act in any way )
