Hi @Mint, thanks for the warm welcome! Not far at allHi Alan andto the forum from me too, not far away in Stafford.
Thank you again @colb Bits purchased. As soon as I have them, I'll get the bushes fixed and test the motor. I've found the threadsYes Creator 310+ for BMW's
As to seat motors here is the parts diagram from Realoem site https://www.realoem.com/bmw/en/showparts?id=CM12-EUR-12-1999-Z3-BMW-Z3_19&diagId=52_0807
Two motors under the seat one for forward/backwards and the other for up/down.
Apply 12v to the motor that's out to see if it works. If it runs put it back in and test using switch, if it fails then look at switch and wiring.
As to the rocking seat, replacement seat runner bushes can be sourced here or on ebay
Threads on here showing how to do this job if you do a search.![]()
Seat Runner Mechanism Replacement Bush Kit for BMW Z3 Z3M
BMW Z3 Z3M Seat Rail Track Runner Subframe Mechanism Replacement Bush Repairx8r.co.uk
Lovely! Looks a little less warn than mineAs you can see,my 2.8 also had the same interior as your car Alan.View attachment 314445View attachment 314447
Thanks for the welcome, Ian and SueHi Alan,from North Yorkshire.
Ian & Sue.![]()
