Part 2 is now in full swing, we now have the time to give this Zed a good look over front and back. The back looks good still and it should seeing as we only did this 9 months ago.
The key jobs this time round are clutch & gearbox and to address some MOT advisories. What we’ve found so far has been really interesting.
First up we found the battery totally flat so we entered the garage under man power. Will see if we can get some life back in her.
Next Jim was complaining of submarine like conditions in his boot. This looks like the typical 3rd brake light seal as well as light seals.
soaking on the inside.
then it was time to empty the lights.
Light fittings starting to suffer.
First of the larger bits of hardware to come off. The lightest exhaust system I’ve ever come across for a Z3 and a crispy cross brace with holes in.
you’d be right to think that’s a small cat. Then if you look inside you’ll see why... it’s empty
It’s done 3 MOT’s in Jim’s ownership I reckon he’s got a good deal going
or it might be the 1.9 vin number in the window ![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
quick photo of the existing hardware we did in March all still looking smart.
we then thought we’d have a look up front. Jim said it did feel strange. We think we might have a good reason why. OEM lollipop bush one side and an powerflex (half fitted) the other side. We also notice one Meyle HD wishbone and a stock one the other side upsets my OCD![Rolls On Floor Laughing =)) =))](/assets/rofl.gif)
Another issue Jim noticed was it running a little lumpy so we quickly spotted a few holes in the intake boots, hopefully a quick fix there.
We also fitted @Mazza PROTOTYPE fuel tank straps to Jim’s Zed in March it’s worth noting these don’t reflect the finished article so will be changed for a fresh complete set.
you can tell they’re the prototype from the brush strokes.
Most parts have already arrived so Monday we’ll be removing the gearbox and odd wishbones. Be nice having everything matched again with fresh wheel alignment, we also have thicker rear spring pads to give her a bum lift![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
