AC and Recycle Switch: LED Upgrade.
Both bulbs had blown, so it was either replace with filament bulbs, or LEDs. LEDs won, so I used the same ones as the HVAC, 12V white LEDS with inbuilt current limiting resistors.
If you do this, make sure you do it slow and methodically, there are a lot of small parts that tend to fly off as you dismantle, modify and then reassemble. So, for a switch that is currently £120 from a dealer, be careful! Take lots of pictures, make notes, or ensure you have a good memory!
The 2nd orange condom (it makes the filament bulb glow BMW orange) broke when i tried to remove it! Smallest condom I have ever broken!
PS, its in the top left of the picture below, its brother survived. I will save that one for later!
When you pull the bulbs out, be firm but gentle as the bulbs easily break. To replace my broken plastic condom I used plastic orange sheet and inserted discs cut to size inside both buttons. The grey bulb holder holes which are too small for the LED's legs, so they had to be opened up with a pin (the bulb holders holes, not the LED's legs!
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
). Note the orientation of the LED when you put it in. I marked the -ve (cathode) with a black pen. When you trim the legs then bend them over, look for the very small indents on the grey bulb holder, ensure these are the sides you bend the wires into as they form a "bump" which ensures the bulb holder and LED is held firmly in the switch body when inserted.
I placed the white body on a small metal post when I pushed the LED and bulb holder back inside. This ensures you do not accidentally force the bulb holder retaining clips and contacts out from bottom. Orientate the LED -ve to the same side as the smallest (copper coloured) spring, which I had also marked with a black line. If the small spring falls out, the picture shows the orientation of the curved part of the wire for insertion.
If you succeeded, applying ground to pin 6 and +12V to pins 2 and 8 should prove your LED upgrade / modification works before you reinsert it into the car.
Parts:
LEDs: https://www.rapidonline.com/4-8mm-low-profile?Attributes={"Forward Voltage Typical":["12V"]}
Order Code: 55-2878
MPN: OSW4G456F1A
UPDATE: The LEDs are too bright. I will either have to limit the current, place a filter in button cap or source LEDs with a lower luminosity.
