Ah, with the upload limit, some of these photos are out of order, but should be clear enough what's going on...
Rear screws removed (should have been the first step...)
Now with the old and new center box on the floor beside each other, I've just realised they're exactly the same! The only difference is the lid bracket which is easily swapped over...
I had intended to swap the front storage box over (so that my key would still work) but it would probably make more sense if you were doing this mod in the future not to waste your time removing the box...
Anyway, next step is to remove the turret covers, although again, I now wonder if that's really necessary. You'll see later that you need need access to the Hoop securing screws, but two well drilled holes would give you all the access you need.... Anyway, I have the proper parts so we continue...
Screws out...
Undo the seatbelt from the seat and thread it back through.... and it's out...
See, side by side, that access panel (left) and the alternative wind deflector (right) is the only difference. If you don't have the right part a few holes in your current parts would do rightly...
![DSC_1518.jpg DSC_1518.jpg](https://zroadster.org/data/attachments/72/72036-a1d4be1e64c8a5ded1296d8831efaab9.jpg)
Next, to remove the wind deflector mounts...
![DSC_1519.jpg DSC_1519.jpg](https://zroadster.org/data/attachments/72/72037-1ea561fd0ccb5ddf69e4f216198ea494.jpg)
Ehh, I've just realised there's one screw missing from the deflector mounts, and what's this from???
Having now just checked the history, this was a dealer fitted option, not factory and this has probably been rattling about for the past 20 years...
Just thinking further, have we just found the source of the 'suspension' tapping noise??
![DSC_1520.jpg DSC_1520.jpg](https://zroadster.org/data/attachments/72/72038-7deef027da22efb0eebe2878378e7dcc.jpg)
Anyways, slide the mounts out...
![DSC_1521.jpg DSC_1521.jpg](https://zroadster.org/data/attachments/72/72039-17f3492b2ab8167e5656a27ac13e1397.jpg)
And that's the strip out complete...
It's starting to get cold and dark, so i'll pick this up next time, when i get round to fitting the new bits...
![DSC_1529.jpg DSC_1529.jpg](https://zroadster.org/data/attachments/72/72047-38c1cbe2f924a4adf9f23e8b7af04c1c.jpg)
