I have a feeling my viscous fan on my M54 (3 litre) is not operating as it should. I have searched about this but am still confused.
So...here is my scenario....
My viscous fan runs from cold but doesn't seem to speed up (much) when the engine gets hot. It does alter it's speed but not by much. I tested it by putting a bit of white tape on one of the blades and watching it with a torch shining on it.
The engine gets to operating temperature (90c ish) then slowly gets hotter. All the time the viscous is running, but it doesn't change it's speed much at all (but does a bit).
When the engine gets just over 100c, the auxillary/ A/C electric fan kicks in and cools the engine back to 90c ish but the viscous doesn't change, it just keeps 'ticking over'.
I am not sure this is the way it is supposed to work. I was under the impression that the viscous should maintain temperature and the electric fan is only there if more cooling is needed that the viscous can't do when flat out.
Can someone please confirm whether my viscous is playing up, or this is normal with this engine?
