It's not old. It's brand new. That firm, Bastuck, manufacture the lights for the classic volvo community. Not cheap either.The thing is with a used lamp you have no idea what bulbs have been forced into that socket before. I refer to my initial comment in the last post. Send it back as not fit for use.
That's why I tagged @Dxbolton in the hope that he's also using the same light and, hopefully, can tell mee whether his bulbs fit or needed some fiddling.There are various pin designs, different heights and angles, I have been caught out before. If you get the wrong one you get the problem that you have.
Well, obviously it doesn't look new (to me anyway) from the pictures. If that's new it's pi55 poor quality. Even more reason to return to sender?That's why I tagged @Dxbolton in the hope that he's also using the same light and, hopefully, can tell mee whether his bulbs fit or needed some fiddling.
Whacked mine with a pointy hammer I've managed to get a decent bulb fit. But I don't trust it.Sorry for the late reply,
I have a loose bulb too in one of my bulb sockets.
It’s also the same make as yours. I tried various bulbs I had available and they were not great. They are ok now but you’re correct, fitment is poor for an expensive part
I ended up cutting the inside channel of the boot lid, fitted a couple of temporary brackets either side with a bolt and couple of nuts that when adjusted allowed me to change the angle of the curve to better suit the contour of the body. When I was happy with it, I fitted a couple of metal plates to keep the new angle in position and then removed the temporary bits.Thank you @Piran for posting the hinge pictures in your build thread.
I've decided to attach my boot lid to the grp rear body tub. Temporarily using angle bracket to figure out how (where) to attach the bootlid
Most of the work is to the boot lid. Starts off like this
Need chop the frame a bit but first I made a bracket with welded in captive bolts. Check it fits the hinge
Then change the shape of the frame on the underside of the lid and bond in the bracket with captive bolts.
Fit the lid to the hinge. See the label on the hinge. Mercedes A Class.View attachment 289025
And hope it closes
It's a "very" tight fit. Tribute done a good job with that. Doesn't rub but I suspect it'll knock going over pot holes so I will take off a couple of mm all the way round.
I will revisit that angle bracket later and bond it under tub. But no hurry. Fiat 500 boot handle coming tomorrow. I'll do that and the lock/catch next
Weather seal. Around the rim where the bootlid sits I'll use something like THIS TRIM but currently that won't work because my angle bracket it attached flush under the rim. When I change how that bracket is mounted I'll fit that trim. My biggest 'weather' worry though is the 3 inch gap between the top of the metal inner wing and the f/g tub. I want to use my car all year round so that needs sorting.How are you going to weatherseal the boot?
Are you proposing to fit gas struts, or a manual lid stay?
To be honest I was thinking more of the struts as a 'stop'. If you have the whole assembly fixed to that thin GRP flange with a couple of small screws, you would only need to over-open the boot beyond the hinge travel and you could easily crack the plastic IMO.The bootlid is very light so doesn't need any gas strut assistance to lift it. I'm not planning on using a gas strut.
Indeed! The pre-curser to gas/hydraulic struts.But I'm still thinking of what to do about a support. Furniture stays. Yes. The support used in cupboards with upward opening doors is the same functionality as what some old cars used.
