Off for blasting and powdercoat, not yet sure what colour the wheel will be.
Much front end newness. Going to be a pampered Z3 when done.
Spring is coming DavieHi. RB2, you are doing great give yourself a break and clear your mind for a while.
I've managed to get INPA up and running on windows 10. The car had an ABS warning like and a battery light on when I get it home. The ABSs sensors had seen better days, so they've been replaced. Not so sure about the 113 code, ABS feed back pump. It would be ashame to replace it if the code was caused by something else. The code 108 about permanent power supply. Could that just be that the battery has sat flat for a number of years?
Aye it is but have a little break.Hey it would be good to know your real name?I am sure you were not named RB2.Spring is coming Davie![]()
Snap - Sump Gasket and X-brace not pictured.More powdercoated goodness.. I am just waiting on new engine mounts arriving and I'll start building the front end. I am going to instal toyo Tr1s on the wheels, as that's what I run on my e30 and I can't fault them for wet grip. Something that's a must in Scotland. In the mean time a sneaky look at the wheels. Ignore the picky 1/4 panel for now. Top side rebuild will be phase 2
View attachment 249227View attachment 249229View attachment 249233View attachment 249235View attachment 249237
More nessecity for me. She's bleeding oil from the sump. Only tidy way of getting there is subframe off but that's not for me me to worry about. I just supply the bits.Nice and shiny parts. I did think about doing the sump and bottom end bearings whilst the subframe was out but I think I am going to change the engine even if its just for another m44. My mate has a 75kmile engine in his shed. It'll be phase 2 though after I get it road legal again
