Very true Iain.
ps. Wish I had a quid for every one.
Amazing! Remind me how big the folder is? I have a 30cm-ish one but bigger would be great. Need to make a gearbox/motor mount as well and thinking I'll fold that up.My mate has finally (!) given me the dimensions for the box he wants folded, so hopefully have the folder on its way next Monday.
Bent up some 3mm steel to the crossmember, there’s an extra hole added for a 10mm rivnut I’m adding to mine. Even found some box, I’ll profile that to the cross tube and drill one end of that. I use 10mm id tube in the cross tube that bolts to the chassis so it doesn’t crush. Means you’ll need to drill and weld one side to match your car as there’s no side to side clearance, unlike the standard ‘x’ brace which has loads.
It’s not a chassis modification as it unbolts, but it is significantly stronger then the ‘x ‘ brace. You can adjust the two box section tubes to whatever width spacing/angle you like.
I’ll send with the folder in one parcel, I shouldn’t need that back for 4-5 months.
Are you thinking about "Rivnuts" by any chance?Sorry, didn’t make it home until late.
I’m sure it’s 30 inch, only supposed to take up to 1.2mm sheet but I’ve reinforced the bed with angle so it’ll likely do a bit more than that. Never tried really, I’ve only used it for flanges on repair panels, and a few boxes. Supposed to be mounted to a bench, I bolted it to a bit of box section, chuck it in my big vice when I need it.
For boxes, I’ve found using angle to mount the end of the box makes something significantly stiff. At the same time much lighter, cheaper and less bulky than a square tube frame with a box inside.
Just spot/rosette weld it, fast, secure and easy. Or big rivets. If it needs to be waterproof, seam sealer, or silicone, though seam sealer over paints.
I’ve experimented with bead rolling stiffening ribs, works well but takes lots of practice and planning. Needs a helper as mine isn’t motorised (yet). Not a route I’d recommend you go down, it would significantly slow progress.
I’ll include some temporary rivet pin things I can’t remember the name of at the moment, went over completely to Cleco pins/clamps, faster, and they don’t melt if I forget to remove them.
I hope it's as good as it looks. Likewise loads of uses, from making up unobtainable connectors, to laying out the engine bay, to designing motor mounts, to planning out rear lights. Should be here middle/end of March.Not rivnuts Tony, it’s like a Cleco pin, sort of, for holding panels you want to rivet, or screw together. Stepped end, plastic spacer, knurled top you screw down to lock the end. They have a Name, and I can’t remember it as I haven’t used them in a decade. Tried Google and it just shows Cleco. It’s annoying me now!
I’ll take pics when I eventually make it home.
OOoh, Tom.
I like that scanner, I may order one of those, I have lots of uses at that price.
Yes
I am very pleased! Nice to have a solid one after two rotters.Not to shabby at all, one solid purchase therehas definitely come early.
