So it's that time of the year when @Lee opens his surgery for beleaguered Zeds. This time it's @Nutty_Hazel's Filbert getting some more TLC! Filbert is a 2000 2.0 6 cylinder.
Tonight was a quick session to get Filbert up on the axle stands, and look to get the exhaust off. This will then give us a clean run tomorrow evening to drop the sub-frame and get it on the bench for dismantling. A few pictures from the evening so far.
Poor Filbert looking all nervous!
Up in the air ready to get the wheels off and give him a good visual inspection.
Spare wheel mucky and probably could do with a new one at some stage, but not in anywhere near as bad condition as some we've seen.
Getting to the nitty gritty... New diff bush required as this one has failed - plan is to replace as normal using a PowerFlex as they are incredibly easy to fit.
Exhaust is off. This one had conventional nuts holding it on at the front (unlike the studs on my 2.2i), and took some convincing but came off relatively easily compared to others. The exhaust rubbers on the rear wouldn't come off for some reason despite both of us going at it - so we cut them off!
Rear disks are a little shabby - will go down on the list as an advisory![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
View of the rear beam bush which are completely shot! Better pictures when the subframe is off.
