I hope you find it’s just a blown fuse but I would not be surprised if you’ve fried some wires along the way or even damaged the DME.
I’m on it as soon as I pull in my driveway.ALWAYS remove the Earth, Negative, (--) terminal and tuck it out of the way first. The way you have it in that picture would allow a spanner (wrench) or other metal item to short from the positive terminal clamp to the positive post on the battery. If you remove the earth terminal it cannot.
ALWAYS disconnect negative first and re-connect LAST.
Okay, I want to make sure I’m doing this right.Try running a jumper cable from the battery live post to the + positive jump post on the bulkhead around the outside of the car. You can join the 2 jump leads together for this exercise. This will rule out a fault in the main positive cable from rear to the front of the car.
From what I know there's only the fuel relay hidden under the lower kick panel, here are two pictures:I know there are more relays beneath the dash kick panel. I’m trying to find them, I removed the lower kick panel on the driver‘s side (USA) any advice on where to go from here?
Sorry, just catching upI know another soft top won’t break my bank, but the 10 hour installment might.
Completely dead. I had power to all my electronics before the bad jump. I just had no turnover with the engine. I had a fault somewhere (not the hazard switch) that was sending my hazards off. They went off endlessly, I disconnected my battery to avoid draining it. A reckless attempt at jumping the car got my power back but no turn over again, a day or so later and a brand new agm battery later I hook it up expecting my hazards to start going off again (like they usually did when I had power hooked up) but nothing. NOTHING. Not a headlight, dashlight, radio nothing. We definitely blew something. Connections were not reversed or anything, we just rigged a jump through the trunk with 800 interstate we had and it caused me a lot more trouble than I realized it would. I kick myself HARD, because even when we did it, I knew where the +/- were in the engine bay for jumping, I don’t know what compelled me to think nothing bad would happen. But, I’ll learn from this. Will never make that mistake again. I’ve gone through all my fuses and relays in the bay with a multimeter. Had to change x1 5amp x1 10amp & x2 30amps. Relays were all good. I want to access what I’ve got beneath the dash, but I don’t know exactly what I’m gonna find. If my main is inline with my positive I’ll have to find it. Willing to do, replace, work on whatever I have to.From what I know there's only the fuel relay hidden under the lower kick panel, here are two pictures:
z3-roadster-forum.de - wo befindet sich das Kraftstoffrelais (8373700) - 38973 - Technik Antrieb
z3-roadster-forum.de - die Community exklusiv für BMW Z3 roadster/coupe-Enthusiastenwww.z3-roadster-forum.de
What's the actual problem with your Z3? Does the speedometer light up when you turn the key or is it completely dead?
Thank you kindly! I appreciate you taking the time to read and reassure me. It makes me feel better that it was your first time installing as well, gives me a bit more confidence. I haven’t gotten quotes around me, but I definitely will considering that I know now just the fabric can be refurbished or replaced. I might even just go to one of these shops to get information or advice too. The video is a huge help, thank you! I’ll definitely look more into doing it myself. Not just to get it done, but I’d love to know how. Have that kind of job under my belt to help others. My rear window finally gave yesterday, a small hole opened up in the lining, I might simply silicone it, however it’s another good reason to address the top. Thank you John!Sorry, just catching up.
Presuming the actual frame of your roof is good, here in the UK there are a few shops that specialise in replacing the fabric (and window) on your existing frame, it costs between £400-1000 and takes about half a day, have you looked for anywhere near you that offers a similar service?
Alternatively, if you do go down the route of replacing the roof, hopefully I can reassure you that the job is not as daunting as it might seem. I did mine a few weeks ago (I had just had the roof fabric replaced, and spontaneously decided to change cars).You can remove the seats and strip the rear trims and hoops to make access (much) easier, in which case your 10hr estimate is probably not far off, but it must be possible without (see shops who can do it in half a day, including putting new fabric on the frame!). Actually removing the one old roof, cleaning up mating surfaces and fitting the other one only took me a couple of hours and was the first time I had ever attempted it. Make sure you have a helper when it comes to physically moving the roofs, they aren't super heavy, but they are awkward and have lots of hard edges and corners that would make a mess of paintwork if they touch.
I watched a few youtube videos before I did mine and this was probably the one I found most useful
View: https://youtu.be/eTo6dzgOZx0?si=dYBDf9SNkqzVnjDQ
Good luck!!
When looking for electrical issues, in this case fuses, it is good practice to start from the largest and work your way down. Having no power at all, it will be something big. You also have a method and don't keep re-checking things that have already been addressed.Completely dead. I had power to all my electronics before the bad jump. I just had no turnover with the engine. I had a fault somewhere (not the hazard switch) that was sending my hazards off. They went off endlessly, I disconnected my battery to avoid draining it. A reckless attempt at jumping the car got my power back but no turn over again, a day or so later and a brand new agm battery later I hook it up expecting my hazards to start going off again (like they usually did when I had power hooked up) but nothing. NOTHING. Not a headlight, dashlight, radio nothing. We definitely blew something. Connections were not reversed or anything, we just rigged a jump through the trunk with 800 interstate we had and it caused me a lot more trouble than I realized it would. I kick myself HARD, because even when we did it, I knew where the +/- were in the engine bay for jumping, I don’t know what compelled me to think nothing bad would happen. But, I’ll learn from this. Will never make that mistake again. I’ve gone through all my fuses and relays in the bay with a multimeter. Had to change x1 5amp x1 10amp & x2 30amps. Relays were all good. I want to access what I’ve got beneath the dash, but I don’t know exactly what I’m gonna find. If my main is inline with my positive I’ll have to find it. Willing to do, replace, work on whatever I have to.
