Hope nothing falls on those fancy footwear !!Subframe out and @GazHyde standard wear in the background lol..
I've had experience on how very small measurements can make big difference in handling.looking at the pic of the subframe does the inboard swingarm clamp look distorted or is it just the pic?Great read and top job as usual chaps.
If I'm honest Hugh I wouldn't know as basic mechanics is my limit. Not sure if mine handles as it should as mine is the only one I've driven so no real point of referance. Feels OK but I think the rear tyres are not so good (make wise) so I'll see when I come to put better ones on next year.I've had experience on how very small measurements can make big difference in handling.looking at the pic of the subframe does the inboard swingarm clamp look distorted or is it just the pic?
Are they steel toe caps @GazHyde?I'm getting dejavue. Here's a pic from last year:
Shorts on February evening-check
Rusty Z3 subframe folorn on the garage floor- check
Knackered bushes - check
Yep it's the Z shed!
Have to say that Lee's Z shed footwear in this pic is much smarter than your trainers Gaz..seems dress code is slipping..
If the rubber bushes are shot, there isn't so much resistance to removal of the pivot bolts. You only discover that when you're trying to re-fit the bolts through new bushes and find that they won't align because something is bent. Also removal is often hindered by the arm not being in the correct "plane" , ie, maybe should be held at a level above or below the perpendicular.
