Thanks matie.Here you go Dawn. @ktnez99![]()
Will they match the existing colour, do you know?I used two 250 ml dyes the lighter colour i used nearly all of it the darker one i have loads of left.
Its not much more expensive to order bigger amounts the cost is the mixing its odd they quote £13 for 65ml and its only £16 for 250ml it has a 3 year life just as long as you store it somewhere it doesn't freeze.
Yes Dawn. Get the code from the BMW archive website unless someone knows it already and they will mix it for you. It's only £17 ish for the larger bottle.Will they match the existing colour, do you know?
Thanks.Yes Dawn. Get the code from the BMW archive website unless someone knows it already and they will mix it for you. It's only £17 ish for the larger bottle.
@t-tony is this the website you use, by any chance? If so, what’s the web address, please?It's a website, you pop the last 7 digits of your chassis number into it and it gives you the original build list from the factory. Can anyone pop the link on for me Please?
